TPI harness help
Old Jul 30, 2017 | 07:26 AM
jdawg77's Avatar
Car: 1989 convertible
Engine: 383
TPI harness help
I am removing my tpi setup and there is a plug that is in the same harness but does not go to the ecm. Does anyone know what this one is for? Thanks in advance.
Im holding the male side of the white plug below.
Old Jul 30, 2017 | 12:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI harness help
C207
http://www.austinthirdgen.org/mkport..._1992_C207.gif
Old Jul 30, 2017 | 12:09 PM
Engine: Lb9
Transmission: M20
If you want to retain your speedometer you can use this.c207 has the output to the iP iirc brown or grey.
The yellow wire at the ecm pin b10 is the vss 4k ppm input.
https://m.summitracing.com/parts/dak-sgi-5e
Old Jul 30, 2017 | 07:56 PM
jdawg77's Avatar
Engine: 383
Thank you again!!!!
Old Jul 31, 2017 | 06:48 PM
Engine: Lb9
Transmission: M20
Not sure if you still have a automatic transmission, if you do you should look into this lockup kit.
https://m.summitracing.com/parts/tci-376600
Old Jul 31, 2017 | 08:42 PM
jdawg77's Avatar
Engine: 383
Ordered!! You are a wealth of knowledge and i for one appreciate all the advise.
Old Jul 31, 2017 | 08:48 PM
Engine: Lb9
Transmission: M20
No problem, the only other obstacle I think you need to look into is a fuel pressure regulator to drop the high pressure to run with a carb.
https://www.thirdgen.org/forums/carb...fuel-pump.html
https://m.summitracing.com/parts/msd-29387/overview/
Old Aug 1, 2017 | 12:23 PM
jdawg77's Avatar
Engine: 383
Good thing I live by Summit Racing.
