Mystery wire please help identify?
Old Jul 30, 2017 | 12:22 PM
bowtie-usa's Avatar
Car: 1988 Firebird Formula
Transmission: 5 Speed
Wiring experts, your help is needed. Thanks
I noticed this connector and wire on the drivers side after the car had some work done recently, a shop installed new valve cover gaskets.
The loom comes through the motor mount on the driver side.
Never noticed it before, but I tied it up with a zip tie for now.
Single wire blade connector green in color.
88 Firebird Formula 305 TBI with open air cleaner mod.
Old Jul 30, 2017 | 12:28 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Mystery wire please help identify?
Somewhere in the area of the two sparkplugs there should be a temperature sender(or switch) screwed into the head that the mystery wire is supposed to be connected to .
Old Jul 30, 2017 | 12:31 PM
Precisely what he said:
Temp gauge sending unit.
Between #1 & #3 spark plugs.
Old Jul 30, 2017 | 12:34 PM
bowtie-usa's Avatar
The passenger side head has the radiator fan switch to kick the fan on at 215 or so which I just replaced recently.
In the 1st picture up on top on the intake manifold by the thermostat is a sensor (2 wire yellow/black connector) that I thought is for the coolant temp sender for the dash gauge?
Old Jul 30, 2017 | 01:16 PM
OrangeBird's Avatar
Car: 1989 Firebird
The black/yellow one is for the ECM .
Rather than rely on one sender to tell the ECM , and then the ECM tell the gauge as most folks think it does , on our cars there is a temp sender/switch for each function .
One for the ECM , a second for the radiator fan (which is also controlled by the ECM*) and a third for the dashboard gauge . If you had a TPI with a separate "cold start injector" then there would have been a fourth one for that . A final fifth (or fourth in your case) would be the "IAT" (Intake Air Temperature) sender mounted somewhere in the air induction system .
* The radiator fan can run from either it's own temperature sender(switch) or from the ECM sending it a signal just in the same way as the fuel pump can run from it's oil pressure sender(switch) or from the signal the ECM sends it .
bet ya didn't think you had that many temperature measuring devices kicking around under the hood , huh ?
Old Jul 30, 2017 | 01:40 PM
bowtie-usa's Avatar
^^^ Thank you Sir!, it makes more sense now.
Also explains why my Temp Gauge has stopped working on the dash cluster!
Old Jul 30, 2017 | 06:59 PM
Cars have had temp gauges since long before ECUs.
A clue is, the temp gauge wire has that old old old style connector, whereas the CTS has the computer style.
