Vss module
Old Jul 31, 2017 | 02:36 PM
randallp504's Avatar
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
Vss module
I have a 1983 Camaro with cable speedometer and remanufacturred 700r4. The car previously had 200r4. The speedo cable needs to be changed and the cable goes into vss and then another cable into trans. What is the vss needed for since it's cable speedometer? What is it signaling? The car doesn't have cruise control, and the vss wiring Is old and crumbling when I'm trying to change speedo cable. Randy
Old Jul 31, 2017 | 06:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vss module
The vss could be used for lockup if equipped . I don't know the capability of your ecm assuming it's ccc.
Old Jul 31, 2017 | 08:06 PM
Engine: 305 HO
Axle/Gears: stock
Re: Vss module
yes it's ccc but doing ls swap /t56 within the next few weeks and wondering if it can assist me with anything for my speedo gauge
Old Jul 31, 2017 | 08:33 PM
Engine: Lb9
Transmission: M20
Re: Vss module
Sounds like you can ditch the vss but get a conversion done on the t56 tailhousing.
http://m.ebay.com/itm/GM-T56-Cable-D...%257Ciid%253A6
