dash lights
Old Sep 6, 2017 | 09:02 PM
Beane63's Avatar
dash lights
I decided to change my stock guage lights out with leds. all of the lights worked until I broke one of the stock lights while trying to pull it out. all the lights in the cluster shut off and I have no idea how to get them to work again. I have the 1982 z28 v8 5L. anyone have suggestions?
Old Sep 6, 2017 | 09:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: dash lights
OOPS
Old Sep 11, 2017 | 06:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
Make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe BOTH sides of the INST LPS fuse.
If there is no power both sides check for power on the
orange wire at the headlight switch.
Then check for power on the
dark green wire at the headlight switch.
Is there power on both wires?
Happy Racing !
Licensed To Thrill
