CS144 Belt size?
Old Nov 1, 2017 | 07:02 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
CS144 Belt size?
Hey guys, I am upgrading my 5.0 TPI with the CS144 alt following these instructions: http://sethirdgen.org/cs144.htm
Now I need a longer belt, my belt setup is stock, with A/C, Power Steering, Smog Pump... Stock length for a 91 TPI should be 6PK2400... how much longer needs the belt to be? Can't find any information for a stock setup. Someone said you need 6PK2540... isn't that a little bit too long?
Thanks!
Old Nov 1, 2017 | 10:34 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: CS144 Belt size?
Unfortunately, you're probably just going to have to measure it on your own. Wrap all the pullies with a piece of wire or string and measure it when done.
Old Nov 1, 2017 | 12:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks!
WOW! That method is much more complicated than the CS144 upgrades I have done! Especially considering that bracket is almost impossible to source now days.
I literally take a CS144 for a Vortec 350. Drill one mounting hole slightly larger. Use one longer bolt and a nut and it bolts to the OEM bracket setup. The ones I have swapped I use a 2" longer belt than factory.
Old Nov 1, 2017 | 02:07 PM
Really? Do you have a # number for a direct fit CS144?
Old Nov 3, 2017 | 06:15 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
http://www.rockauto.com/en/catalog/c...generator,2412
Old Nov 3, 2017 | 06:16 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
btw I did the cs144 upgrade and just ended up using the same belt. it was just tight.
