How to test electronics in a roller?
Old Dec 6, 2017 | 05:21 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I purchased a nicely optioned parts Trans Am but it has no engine. Is there an easy way to test power items to see if they work before removing them: power seat, Radio, headlight motors, power windows, etc...
Old Dec 6, 2017 | 05:40 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: How to test electronics in a roller?
If the harnesses are still intact just hook up a battery. Just connect the starter wires to the positive terminal and ground the battery terminal to the body - done. Electrical accessories don't care if the engine is in there,... they just want power and ground.
Old Dec 6, 2017 | 06:04 PM
Drew's Avatar
Might want to ground the ground wires that would be at the back of the cylinder head, and of course the negative battery cable.
Old Dec 6, 2017 | 11:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I wouldn't spend much time on testing electronics, either it's a good deal or it's not. If the owner can't prove anything or everything works you use that as a bargaining chip. Unless everything is there and hooked up you could spend an entire afternoon checking grounds and continuity. Is there even a key to check the switched power items?
Old Dec 7, 2017 | 07:26 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
You can use a multi-meter on the connections for various components under the hood to make the needles bounce in the cluster, but that's about it.
Same goes for the power windows/etc. Just unplug them and hook up a power source (battery, etc.).
Old Dec 7, 2017 | 06:40 PM
battmann's Avatar
The car is complete accept the engine is gone. All of the engine bay wiring is just hanging there. I got the car to help me restore another car and wanted to see what items work before spending time to remove and install them on the good car.
wesgmc
May 26, 2010 09:47 PM
91rsowner4life
Jul 26, 2005 09:35 AM
SLP IROC-Z
Oct 24, 2004 11:03 PM
Cornflakekid
Northern Great Plains and Rocky Mountain
Oct 25, 2001 05:25 PM
