Relay ?
Old Feb 20, 2018 | 08:41 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Relay ?
Relay messing up ? Its wired into the neutral safety switch wiring. Its in between the thick yellow wire. It messed up once before and the car wouldn't start and I messed with the wires and it started. Would removing the relay and putting it back to factory be fine ?
Old Feb 20, 2018 | 11:35 PM
Drew's Avatar
Re: Relay ?
Deja vu.
WTF dude.
https://www.thirdgen.org/forums/elec...217-relay.html
Old Feb 21, 2018 | 09:38 AM
Re: Relay ?
Sorry forgot about that thread
Old Feb 21, 2018 | 11:11 AM
Re: Relay ?
Something had messed up with their wiring I believe because yesterday the car wouldn't start. I swapped the good neutral safety switch in out of my other car and it still didn't start. So I replaced the relay and still no change. I ended up using a wire and connecting the yellow wires back together and it started. Do you think its fine to just wire it back the factory way ?
Old Feb 21, 2018 | 06:22 PM
Drew's Avatar
Re: Relay ?
Yes. At one time it was most likely a starter defeat for an alarm. Now it's just a headache waiting to happen.
Old Feb 21, 2018 | 09:12 PM
Re: Relay ?
Turned out it was a kill switch and I found what was controlling it
Randy82WS7
Jun 9, 2003 11:08 AM
Iroc_Z28
Jan 28, 2002 05:41 AM
JT 85 TA 305
Dec 8, 2001 06:15 AM
88gta305
Feb 1, 2001 03:48 PM
