Starter Problem
Old Mar 7, 2018 | 12:19 PM
85Gabe's Avatar
Car: 1985 Camaro Sports Coupe
Engine: 5.7 with some extras
Starter Problem
I have a sbc 350 and a few weeks back the engine stopped cranking. I went through and the ground wasn't connected connected to anything so I fixed that. Still the same result, I wired a push button to eliminate any problems with the ignition and that worked until a week later same issue. I replaced the starter, alternator and its got a new battery. Now I can just hear the starter and flywheel I think, turning very slowly.
Old Mar 12, 2018 | 07:51 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Starter Problem
Had a similar problem with mine and it wound up being a multiple part fix. Went with a ford starter solenoid and replaced all the wiring to and from the starter. Half of it was rubbish and the trigger from the key had a crystalised patch of wiring that would sometimes allow voltage through but sometimes not.
jamesmc03
Dec 20, 2003 08:55 AM
hookin88formula
Oct 22, 2000 08:36 AM
