Relay switch
Old Jul 13, 2018 | 06:10 PM
Skunkdad's Avatar
Want a title? Post!
Relay switch
I have a 28!model A with a stock 350. I keep burning out relays. The fan is a new puller located between the radiator and the engine. The fan kicks on a 190 degrees and the engine normally runs at around 200. I see some burn issues at the plug located under the dash at the fuse box. I have a separate switch for the fan which I keep turned off. Any ideas.
Old Jul 14, 2018 | 09:38 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Relay switch
Originally Posted by Skunkdad
I have a 28!model A .......
Just wondering , exactly , what in the Hell IS a "28!model A" ????
Filling in your user profile with exactly which GM third gen F body car you own will go a LONG way towards getting some meaningful answers here ...
Old Jul 14, 2018 | 12:37 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Relay switch
The fan kicks on at 190 and the engine runs at 200? First fix that the fan should not be running when the car is cruising.
Also what car do you have and what year?
Old Jul 17, 2018 | 04:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
1928 And It’s Just Broken In
Pertaining to your 1928 model A Ford, too much resistance at the socket contacts.
The reason(s) is/are the contacts are dirty, the socket is of cheap construction and the contacts were made from too thin metal.
If the latter, upgrade to at least a 70 amp relay and socket.
Happy Racing !
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
dragonmas
Dec 14, 2016 08:28 PM
johnw999
Oct 25, 2016 06:46 AM
Mike5396
Oct 23, 2016 03:51 PM
Aerothyr
Oct 6, 2016 08:46 AM
Crunchy Frog
Sep 27, 2016 08:18 PM
