Help with C100 wiring.
Old Aug 9, 2018 | 08:52 PM
Matt Dunn's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.0 305 TPI
Transmission: 4 Speed Auto sadly
currently wiring up my ls carb swap. Have most of it figured out other than the A4 red wire and the G5 red wire. I am not completely sure about where they are supposed to go to. From what I read it says something about a power distribution block but I can’t find that anywhere. Anything will help! Thanks
Old Aug 9, 2018 | 11:21 PM
Drew's Avatar
Re: Help with C100 wiring.
On a 91 GTA? G5 goes to the positive post on the starter with a fusible link. Powers the lights mostly. A4 goes to the same place on a different fusible link and powers damn near everything. If your diagram says "distribution block" you're probably looking at a TBI or 3.1L diagram, TPI cars don't have a block, they run everything to the starter. Pages 8A-10-2 8A-10-3, and 8A-10-4 are where you'll find those wires in the 91 Firebird manual.
Old Aug 10, 2018 | 02:53 PM
Matt Dunn's Avatar
Engine: 5.0 305 TPI
C100 layout.
Old Aug 10, 2018 | 05:36 PM
Drew's Avatar
Yeah whoever made that diagram wanted it to be universal, or they just want to call the positive at the starter a dist block. Doesn't matter much, just on tpi cars everything runs off the starter and everything else uses a block by the battery.
blackbeauty
Oct 29, 2020 09:03 AM
Drone358
May 28, 2015 11:06 PM
jtmiller92
Jun 22, 2006 09:09 PM
jtmiller92
Jun 22, 2006 08:35 PM
blackbeauty
Apr 24, 2006 01:07 PM
