Vortec/LT1 Style Starter
Old Aug 14, 2018 | 10:27 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I've read the recommendation here several times that when the factory starter dies (or even before then), that an easy/cheap/effective upgrade is to the later style L31 or LT1 starter.
I had the joy of taking a day off work today to change the starter on my L31 powered Express van. The starter has a hefty heat shield on it (good).
As you can see, the proximity of the exhaust manifold to the solenoid makes this shield pretty essential.
Are the clearances similar in an F-body? I can't imagine that they are not. Does the F-body use a similar shield? Or is there no room for one?
Old Aug 14, 2018 | 10:39 PM
skinny z's Avatar
Re: Vortec/LT1 Style Starter
I've never used the shield, so I can't comment on the fitment but can say that without it, I've never had a starter issue. Heat soak related or otherwise.
I'm using Hedman LT headers and not manifolds though.
I should qualify that by saying that I did have alignment issues. It was necessary to use a shim to keep the starter gear from crushing the flywheel.
Old Aug 17, 2018 | 09:53 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
The heat soak issue with stock 3rd gens is usually only present after swapping in headers. I think the recommendations to swap in one of those starters regardless is largely due to simply being a smaller size. Personal experience: bought an 89 IROC with headers already on and a severe case of no start once warm, LT1 starter fixed.
Old Aug 22, 2018 | 07:02 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I upgraded to an LT1 starter due to a no start after heat soak issue running SLP headers. It fixed the issue. I can now remove and install the starter without first removing the header now, and it weighs signifigantly less than the stock starter.
Other than it being a tighter reach for the wiring, I wouldn't hesitate to swap.
Justin89Formy
Jul 3, 2013 10:02 PM
xpndbl3
Feb 19, 2009 09:25 PM
scooter500
Sep 15, 2008 05:47 AM
