Fuse of obd?
Old Aug 28, 2018 | 11:28 AM
DirtyDan's Avatar
Car: 1992 Camaro RS
Fuse of obd?
I have a 92 RS and I wanted to connect my obd reader to see if there were any codes coming. But either the obd port has went bad or not getting power. I've made sure the scanner works on another car. Any suggestions?
Edit: this car is a 305 tbi I see that I made a mistake.
Old Aug 28, 2018 | 11:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuse of obd?
The obd port doesn’t supply power to a scanner.
Old Aug 28, 2018 | 11:41 AM
Engine: Lb9
Transmission: M20
Re: Fuse of obd?
DirtyDan's Avatar
Car: 1992 Camaro RS
Re: Fuse of obd?
​​​​​​I know but does the port it self not draw power from somewhere?
Old Aug 28, 2018 | 11:45 AM
Engine: Lb9
Transmission: M20
Re: Fuse of obd?
Pin m is the serial data line.
Old Aug 28, 2018 | 11:47 AM
Engine: Lb9
Transmission: M20
Re: Fuse of obd?
Old Aug 28, 2018 | 12:15 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fuse of obd?
Forget the 'scanner' and go old school,.... Use a paperclip.
Old Aug 28, 2018 | 12:19 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
Re: Fuse of obd?
No idea what you mean
Old Aug 28, 2018 | 12:22 PM
John in RI's Avatar
Re: Fuse of obd?
https://www.obd-codes.com/faq/read-gm-2-digit-obd-codes-free.php
Old Aug 28, 2018 | 12:43 PM
Engine: Lb9
Transmission: M20
Re: Fuse of obd?
I didn’t know sr came with tpi is this a conversion ?
if it is I think pin e goes to m on the aldl.
https://www.thirdgen.org/forums/tpi/...esnt-fire.html
Old Aug 28, 2018 | 12:48 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
Re: Fuse of obd?
None that I'm aware of
DirtyDan
Aug 28, 2018 12:55 PM
