ECM removal & need help with electric speedo.
Car: '84 Camaro Z28 H.O.
Engine: L69 305 H.O.
I've got a 84 Camaro with an 700r4 in it that has an electronic speedo. I want to remove the ECM entirely and the only problem I'm facing is how my speedo will work without it. According to what I could dig up, the trans has a little square plug that goes into the ECM and then the ECM goes to your gauge. Is there any way around this? I have to use this trans, but I absolutely will not have the ECM if I can, in any way, remove it.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM removal & need help with electric speedo.
Are you sure you don’t have a cable drive speedometer. The plug might be for tcc lockup.
Goodolboy0404
Sep 17, 2016 07:26 AM
Ozz1967
Jan 9, 2014 08:40 AM
