Vacuum Adv Distributor Swap And Tach Help
Old Dec 21, 2018 | 09:19 PM
Super64!'s Avatar
Car: '84 Camaro Z28 H.O.
Engine: L69 305 H.O.
Hi. I have a '84 Camaro Z28 with a stock L69 305 HO engine. The distributor's advance is computer controlled and I'm removing the ECM so I want to swap the distributor. My plan Is to take an old HEI vacuum advance one off of an engine from my collection of SBCs from 70s & 80s GM vehicles I have laying around. I don't really know anything about tachs so my question is do I need a specific kind of distributor if I wanna keep my factory tach working in my stock gauges? I know the tach gets its reading from the distributor, but can I just use any random HEI and make it work? Do I need a specific type of distributor to plug into the tach wire? If so, Is it possible to modify one to be able to use a tach if I don't have one?
Old Dec 21, 2018 | 09:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vacuum Adv Distributor Swap And Tach Help
You can use any hei coil in cap. There is a terminal in the side of the cap marked tach .
Old Dec 21, 2018 | 09:25 PM
Engine: Lb9
Transmission: M20
Old Dec 23, 2018 | 10:22 AM
You don't have to "do" anything. Just plug it in. the older HEI wires up exactly the same as the one your car came with.
zed-028
Nov 15, 2016 06:27 PM
ownor
Mar 1, 2012 02:48 AM
atc3434
Jun 19, 2007 10:58 AM
Superblue87Formula
Oct 24, 2000 01:55 PM
