Kent moore terminal trays
Old Jan 9, 2019 | 10:09 PM
texas7's Avatar
Hi
can someone explain the difference between the tray numbers for kent moore terminal ?
its what 19 out of 99 ? What is different between tray 15 and 22?
and the names ?
I’m looking to buy a tray of terminal to rewire some stuff in the engine bay and came across those but i cant find anything about the names and numbers...
if you guy have any place/brand that sell a tray with just terminal let me know i would like to buy something in bulk instead of buying single package....
Old Jan 9, 2019 | 10:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Kent moore terminal trays
Not sure what tray numbers your referring to. You can find gm Delphi connectors in bulk at mouser.com
Old Jan 9, 2019 | 10:32 PM
texas7's Avatar
In the side it says j38125 tray 9 sumitomo ?
Old Jan 9, 2019 | 10:51 PM
Engine: Lb9
Transmission: M20
Looks like they are listed in packard series numbers. What exactly are you looking for ?
Some examples of series
https://www.corsa-technic.com/catego...category_id=83
you can find most connectors and housings in bulk at mouser.
Old Jan 9, 2019 | 11:08 PM
texas7's Avatar
Just looking for female and male terminal to rewire some wires on the engine fuse box harness side...
i wanted to buy a box of terminal to have some on hand for now and in the futur and saw that... but i have no idea what is all the meaning of the box names and numbers....
Old Jan 10, 2019 | 09:55 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You have to know what you're trying to repair to purchase the proper materials. Sumitomo must be a specific connector, or something. GM has used many different connectors, which use different terminals. You can't just blindly start buying stuff and hope to accomplish anything. There is no "engine fuse box" in a third gen. You need to tell us what you're trying to repair, or do more research.
Old Jan 10, 2019 | 05:46 PM
texas7's Avatar
Ya what I mean by engine fuse box side is the driver side c100 connector
And i’m not buying anything in the blindly... that’s why I came here to ask what it was
Old Jan 10, 2019 | 06:03 PM
Engine: Lb9
Transmission: M20
If your looking for C100 parts check out this thread.
https://www.thirdgen.org/forums/inte...onnectors.html
Old Jan 10, 2019 | 07:32 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The C100 uses Metri-pak 280, 480 and 630 terminals, non sealed. There are 6 wires sizes per series. Engine side are male terminals
https://ecat.aptiv.com/feature??search=12015509#
Nice quoting my thread
Old Jan 10, 2019 | 07:49 PM
Engine: Lb9
Transmission: M20
your the Delphi guy
Old Jan 10, 2019 | 08:45 PM
texas7's Avatar
thanks I'll look into this... but still don't know what are sumitomo connectors
Old Jan 11, 2019 | 12:08 AM
Drew's Avatar
The trays cover a lot of different wiring terminals. Pretty sure when I looked into going that way, there were something like 6 or 7 trays for the common GM connectors on a thirdgen. They're expensive, and as a general rule, the trays that a thirdgen enthusiast would want, are the same ones that most shops or technicians aren't looking to part with. Lots of goofy trays like the Sumitomo sets can be found on Ebay because they're uncommon.
C409
Feb 20, 2018 09:37 PM
urbanhunter44
May 26, 2006 11:36 PM
Floor guy
Apr 7, 2006 08:10 PM
