Headlight low beam issue
Old May 30, 2019 | 02:11 PM
Crossfire1983's Avatar
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
Hey everyone, my car is a 1983 Z28 and recently the passenger side lowbeam went out. Now when I switch to high beams all four come on and I replaced the low beam bulb with a new one and it still does not have any low beam on that side. The low beam on the driver’s side does work still. Thoughts on what it might be?
Old Jun 3, 2019 | 10:44 AM
racerx520's Avatar
Re: Headlight low beam issue
maybe the socket is worn out? crown vics at work used to burn up the sockets over time.
Old Jun 3, 2019 | 03:22 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Are you sure you got the right bulb... I don't know the parts off the top of my head but the sealed beam lights can be gotten with a single element (two options here one has no high the other has no low beam element) or dual element (has both high and low in one bulb). My suggestion would be a test light or volt meter and see if you get power to the wires in different switch positions. The socket can be had at most parts stores if it turns out to be the socket.
Old Jun 3, 2019 | 04:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light ☼ ☼ Headed
The left and right headlight sockets are connected VIA a wire.
Make sure that wire is not broken.
It’s possible the wire going into the right headlight socket has a bad or corroded crimp.
Make sure the contacts inside the right headlight socket are clean.
If the above is OK, trace the
tan wire coming out of the left headlight socket to make sure it travels unbroken to the right headlight socket.
Happy Racing !
Rule Number 1 Is To Know Which Rules You Can Break
DrtRkr
Feb 17, 2019 03:59 PM
Spyro
Feb 19, 2016 12:50 PM
tricktrick
Aug 25, 2009 12:24 PM
Monkie
Dec 22, 2001 09:51 AM
