Alarm buzzer going off non stop
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi,
i have an irocz 1986 which i removed the seat to clen the carpet. I disconnected the battery so having the door opened will not drain it. When i reconnected the battery again, the buzzer for seatbelts, lights on etc began to buzz without the key at the ignition. Essentially, i have to disconnect the battery to stop it.
i followed the manual trouble shooting and found the “convenience assembly”. I did the lamp test and the green cable connector failed to light the lamp. I removed the green(square box with 3 teeth)switch at the convenience assembly ( it was actually buzzing). My question is if i just disconnect the switch will that harm or drain my battery if i dont fix the circuit? Is anything else will be affected if i just remove the switch? Thanks in advanced!!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisin’ For A Fusein’
To find out use an ammeter in line with the applicable fuses.
The Audio Alarm Assembly is powered thru 2 fuses.
The ACC fuse, and the Gages fuse.
Happy Racing !
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
Happy Racing !
Tyler-88
Oct 28, 2001 11:08 AM
