Fuse box question
Old Sep 9, 2019 | 06:02 PM
tbeyer's Avatar
Fuse box question
I saw in a wiring diagram for my 86 Iroc that the ign ports on the fuse box go through the guages fuse. Does anyone know where the bat ports on the other side of the fuse box go through. I don’t want to draw too much power and blow a wire.
Old Sep 10, 2019 | 11:19 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fuse box question
This schematic is from the 85 shop manual for TPI,..... You can see the 2 BAT cavities on the Fuse Box and trace them back to the Light Switch, then the 'G5' PIN of the C100 connector and back then to the starters fusible link.
This schematic shows everything factory connected to the ACC fuse in the 85,......
Old Sep 10, 2019 | 11:37 AM
tbeyer's Avatar
So it looks like the bat ports do go through the 20 amp acc fuse. I just wanted to make sure that there was a fuse so I wouldn’t burnout a wire going to the battery. Thank you.
Old Sep 11, 2019 | 07:13 PM
John in RI's Avatar
Glad to help !!
91CamaroRS1122
Mar 5, 2009 11:55 PM
camaro87-alex
Feb 25, 2009 05:16 PM
ss7s
Jul 25, 2006 09:17 AM
TransAm12sec
Jun 30, 2005 10:06 PM
