Oil pressure switch vs sending unit
Old Sep 12, 2019 | 12:42 AM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Is there a difference between the two?
I have an '89 Iroc-Z with the L98. The oil pressure gauge has stopped working. As a matter of fact, the needle is pointing 180* off of where it should normally be. It does nothing when I start the car or shut it down. Disconnecting the battery did nothing. I assumed it was the oil pressure switch just above the oil filter. I ordered an AC Delco unit and replaced the part...nothing changed! I've been researching on past threads and found that there is a sending unit attached to a brass 90* fitting but it was on TBI cars. Do the TPI cars have them as well? I've also read that there are known issues with the rally gauges on these vehicles.
Any help is appreciated, thanks.
Old Sep 12, 2019 | 10:25 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Oil pressure switch vs sending unit
TBI cars just have it in a different location. You won't have one by the oil filter and one behind the manifold.
Old Sep 12, 2019 | 06:56 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
My 88’ L98 has the one by the filter and one by the distributor. The one that worked the gauge was the bell shaped one near distributor, after replacing it my gauge worked much better, not perfect but a big improvement. Also this is one of those things that seemed to change during different model years...I believe 89’ only had the sensor near the filter. Might want to check wiring to see what’s going on.
Motown
Aug 28, 2011 04:05 PM
V8hareed
Aug 24, 2008 04:17 AM
Mavrick
Jul 27, 2005 11:54 AM
VortecZ
Dec 3, 2003 11:33 AM
cmpcpro
Sep 1, 2003 08:01 PM
