Need help with flasher ??
Old Sep 29, 2019 | 10:53 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88 gta
The blinker blinks really really slow left and right
Does anyone know where the flasher is on my car ?
Do I just change it or do I have to do the 4 ways to
I have never changed it ever
Ty
Old Oct 5, 2019 | 11:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Need help with flasher ??
You shouldn't have to replace both flashers unless the hazards are acting up as well.
The turn signal flasher should be clipped to one of the instrument panel supports to the right of the steering column.
The hazard flasher is plugged into the (IN)Convenience Center.
Old Oct 8, 2019 | 12:28 PM
bensbaby's Avatar
Engine: 383 built
Is there a bad ground wire that I can clean to maybe
Old Oct 9, 2019 | 04:18 PM
bensbaby's Avatar
Engine: 383 built
I just fixed it
So I just wanted to say ty
Old Nov 1, 2019 | 08:30 PM
82TAR's Avatar
Car: 82 Trans AM Ricaro
Engine: 305 LG4
Transmission: 3 spd auto
Axle/Gears: 3.23:1
What was your solution in the end? Bad ground? Bad relay?
Originally Posted by bensbaby
I just fixed it
Ozzy88GTA
Jul 28, 2001 02:32 PM
