Where is the Light buzzer on a 87 Camaro
Does anyone have a picture , So I know what I'm looking for, How can I disconnect it (it stays on when the lights are on all the time.) I'll get at it later and fix it but I have much to do till the snow fly's here , So I want to pull it or disconnect it or anything simple to get rid of the Dam Buzzer.
Re: Where is the Light buzzer on a 87 Camaro
It's in the "convenience center", a sort of tray looking thing with the diagnostic connector at the end. It's black, maybe 2" square.
I think you'd be better served by investigating the cause, than removing or disabling it; a faulty key presence switch.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I had one that was white, just to go off what sofakingdom said. You should look for the problem though
Like I said I have much to do before the snow flies and it's put away, it will get fixed in the spring. I've wasted time on this already. I just don't want to listen to the sucker while i'm working on other things.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You can pinch the plastic tabs on each side of the convenience center to allow it to swing down so you can access the relays & audio Alarm mounted to it. The Audio Alarm should look like one of these: ( Partial convenience center shown to the right in this pic )
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
I need to find the light buzzer and plug it back in. I'm so used to all our modern cars with auto shut off I keep leaving the damn lights on. Lol.
