New Build Rewiring
Old Nov 29, 2019 | 01:21 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
New Build Rewiring
On my build I am completely scrapping all OEM wiring in car. As we all know the fuse box swings down under the dash and is connected to the firewall by a bulkhead connector. Since I’m eliminating all wiring I’m looking at using the Painless 25-circuit Pro Series fusebox/wiring setup. Part #10413. All other door, radio, etc. harnesses I will make and all engine/trans/power will be the Holley Dominator harnesses. So here’s my questions: Will I be able to mount the bulkhead connection flush against the firewall in the OEM position or would I have to use the grommet style (Part#10411) and place the fuse box elsewhere? Has anyone ever done this? Will I still need to use the power accessory connector box that is mounted to the left side drivers kick panel? Thanks.
Link to build:https://www.thirdgen.org/forums/ltx-...ld-thread.html
Old Dec 1, 2019 | 09:19 PM
BIRD91ZRAG's Avatar
Re: New Build Rewiring
I was talking to my friend from American Auto Wire last weekend about the same thing for my 82. Hardest part other than the bulkhead connector would be interfacing with the dash cluster plug. If you're able to wire a car from scratch, give them a look. I've used a half dozen of the direct update kits on the Chevelles I've built, it's a quality product.
Jaysz28
Jun 16, 2014 08:19 PM
Nitsuj86Iroc
Aug 4, 2005 03:23 PM
Merlin7734
Nov 2, 2003 06:38 PM
