Turn Signal Not Blinking
Old Dec 26, 2019 | 02:02 AM
Kyler_89RS's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi
I put in an electronic flasher for my new front 2 LED turn signal bulbs (parking lights).
The front left doesnt seem to blink, but the back left one does. The whole passenger side is fine. I guess when you turn on the turn signal, the sidemarker light and parking light light alternate back and forth, but the front left one just stays on and doesnt blink.
The bulbs are from SuperBrightLed’s (which are super cool btw).
Any ideas...
Old Dec 26, 2019 | 08:32 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bright Idea
Did all LEDs illuminate before you replaced the flasher?
HappyRacing!
Some Drivers Use Only One Foot To Drive -- You Can Identify Them -- They Are The Ones Always Crashing Thru Storefronts Or Plummeting Off Parking Garages
Old Dec 26, 2019 | 11:17 AM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Bright Idea
A while ago I replaced them with the same bulbs and they illuminated, but none of them flashed (stayed lit when I flipped my turn signal). Once I replaced the flasher, they all flash, except for the front left parking light.
If this isnt making total sense, then I can take a video of what I’m talking about...
Old Dec 26, 2019 | 12:29 PM
NINÅ's Avatar
Transmission: 765R4
Bright Idea
A common mistake is people installing turn bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
Now once you know the bulb is installed correctly, be advised the "parking light" portion of the bulb is not supposed to blink by original design.
However it will with SOME manufacturers' bulbs.
Different LED manufacturers have different ideas of what is correct.
Some have a separate LED array for the "parking light" element, and for the turn element.
Some illuminate all elements all the time "dimly", however when the turn signal is activated a resistor is bypassed so the lamps' brightness increases and decreases thereby indicating a turn signal.
I recommend using a voltmeter to probe the socket to make sure the correct contacts are getting power when they are supposed to.
You can use the Right turn socket as a reference due to the fact you stated it is behaving properly.
HappyRacing!
Old Dec 26, 2019 | 01:51 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Bright Idea
It was twisted 180 lol. Thank you
1988PontiacT/A
Nov 18, 2019 04:27 PM
91maroRS91
Oct 24, 2010 05:58 PM
Cornholio7979
Feb 1, 2006 07:17 PM
MKnight
Oct 20, 2005 01:16 AM
zNucleaRz
Jan 27, 2004 04:27 PM
