Engine bogs when using power accessories/dead tachometer
Old Jan 13, 2020 | 12:11 AM
IneptusMechanic's Avatar
Once again, I'm trying to fix some issues on my '84 Camaro. This is two different problems, one of which affects every power accessory in the car.
1: Every time I use a powered accessory, the engine bogs hard and the ammeter immediately drops into the negatives and stays there until I come off of idle. This goes for the heated rear window, electric cooling fan, and radio so far. Radio signal is also very unstable; it rapidly goes from loud to quiet and back again. This is a newer radio, and it was wired up by the previous owner. The guy's an electrician and owns his own business so I assume he knew what he was doing. The electric fan also doesn't come on automatically, I have to switch the A/C on to get it to activate, unless you turn the car off and back on again. I'm thinking that's a problem with the sender/sensor for the fan (assuming that's separate from the gauge sender) but it seems odd that it would work automatically only once after the key was turned.
2: The tachometer stopped working about 20 minutes after I purchased the car. No idea why but from what I saw before it died, the car idled at around 750 rpm.
bradfords1990rs
Sep 12, 2010 11:51 PM
DyingYoung138
Sep 8, 2008 09:23 AM
Zralou
Aug 9, 2008 07:53 PM
DA 89 CAMARO
Mar 7, 2005 08:57 PM
