Distributor Swap
Old Mar 1, 2020 | 10:31 AM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
Distributor Swap
Hello all;
I did a search first, but couldn't find anything close to what I am wanting to do. As my sig states, I now have a 85 Z28 5.0l TPI and looking through all of my extra 3rd gen parts (Some I'm going to sell soon), I found a Billet Small Cap Distributor. What do I need in order to swap out the stock Coil in Cap Distributor?
Old Mar 1, 2020 | 11:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor Swap
https://www.ebay.com/itm/Fit-Chevy-T...0AAOSwCMFaOc2k
Old Mar 1, 2020 | 11:49 AM
Engine: 4.7 Liter
Thank you. Unless I need anything else, that should do it. I know I need the remote coil, I'm just saying that's it on the wiring.
Old Mar 1, 2020 | 11:54 AM
Engine: Lb9
Transmission: M20
That’s it on the wiring. You need to splice in the coil to ignition power and the tach lead with supplied harness.
the icm and coil jumper and plug and play.
Old Mar 1, 2020 | 02:12 PM
Yup, just a coil, and some wiring adaptation. Very simple and plug & play. The 2 distributor types are functionally identical, their components are just packaged differently.
Old Mar 1, 2020 | 03:26 PM
Engine: 4.7 Liter
It may be just me but, I always thought the Small Cap looked cleaner, less busy.
Thanks for all of the replies
Old Mar 1, 2020 | 07:41 PM
Engine: 4.7 Liter
Question about wiring up the adapter harness
What do the 2 wires splice into?
And what does this connector plug into?
Old Mar 1, 2020 | 07:53 PM
Engine: Lb9
Transmission: M20
The first image is the coil power and tach wire. Right now these are hooked up to the drivers side of your hei.
the second image is icm wiring. This goes to the passengers side harness flat 4 connector that’s hooked to your hei. Converting it to the small hei plug.
Old Mar 2, 2020 | 02:20 AM
Engine: 4.7 Liter
Thank you. It's been 16-17 years since I dealt with the harness of a 3rd Gen and I just couldn't remember what that flat 4 connector went to. Unless this new ICM on the original CIC (Coil in Cap) distributor, that I'll be putting on in 2 weeks, is not one of the reasons to get it running, then it will be a month before I swap it. When I do, I'll do a write up w/pictures for this thread I started. Like I first mentioned in my original post, I couldn't find anything close to what I am going to do. Unless it was in another part of the tech boards under something else, it should be here in Electronics. I'll just edit my first post to add the write up and pictures.
Old Mar 14, 2020 | 01:49 PM
Engine: 4.7 Liter
Does anyone have pictures of the stock location for the Coil for a TPI? Not the one in the cap, but for the small cap distributor.
Old Mar 14, 2020 | 05:02 PM
Engine: Lb9
Transmission: M20
Should be able to google it.
there are two brackets. One that goes to the back two intake bolt holes on the passenger side.
then the coil bracket mounts to the top of it.
1meanGTA
Sep 6, 2010 07:28 PM
Justin89Formy
Jul 22, 2009 05:06 AM
NEOMASTERZ28
Dec 31, 2003 02:09 AM
ULTM8Z
Jun 13, 2003 09:45 AM
