Should the alternator make a buzzing sound with the key on engine off?
Old Apr 4, 2020 | 08:19 PM
92Z's Avatar
92Z
Noticed a buzzing coming from the alternator with the key on in my quiet garage tonight. Any clues as to if or why it would do this?
Old Apr 4, 2020 | 09:04 PM
Re: Should the alternator make a buzzing sound with the key on engine off?
No it should not do that.
Probably run your battery down if you leave it like that.
Old Apr 5, 2020 | 05:20 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
It sounds like something - maybe your ignition switch - is delivering power to your alternator's voltage regulator when it shouldn't.
Key-on-engine-off, my car makes the same noise.
Like sofakingdom said, that will absolutely drain your battery.
Get out your voltmeter, and check the rectangular plug on your alternator to see which terminals have power, then report back to us with the results.
Old Apr 5, 2020 | 05:36 PM
The regulator (inside the alt) has full battery power applied to it; not all of it comes through the ign sw.
92Z
Nov 8, 2010 01:00 AM
coolrimsatleast
Sep 21, 2009 10:39 PM
DartByU
Jun 8, 2008 05:45 AM
Questor
Feb 24, 2002 10:10 AM
