1989 firebird 2.8l t5 c207 pinout sheet
Car: '89 Firebird
Engine: 7.0L
Re: 1989 firebird 2.8l t5 c207 pinout sheet
I couldn't find it either when I did my engine swap. I put a multi-meter to wire and this is what I figured out (or didn't figure out). 1989 Firebird 2.8L, T5 trans.
A.... BRN.... unknown
B.... PNK/BLK.... 12V power from INJ fuse
C.... BRN/WHT.... MIL lamp (ground this wire to turn on the light in dash)
D.... BRN.... 12V power from FAN fuse
E.... WHT/BLK.... unknown
F.... PNK/BLK.... 12V power from ENG-IGN fuse
G.... PNK/BLK.... 12V power from GAGES fuse
H.... TAN/BLK.... unknown
J.... ORG.... Datalink
K.... BRN.... VSS buffer box speed input
L.... BLU.... VATS
M.... BLK/WHT.... VSS buffer ground
N.... unused
P.... unused
R.... PPL/WHT.... 12V from CRANK fuse
L.... BLU.... VATS
N.... unused
P.... unused
Car: '89 Firebird
Engine: 7.0L
You can verify with wire continuity checks. Just make sure battery is disconnected from battery. Put key switch in proper position depending what you're testing.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
This is what I've got; Can't claim it's 100% - but should be close ! ( see notes for induction specific details. )
1988 C207 (maybe 89 too)
PIN Color From / To (Notes)
A Brn ALDL (pin C) / ECM (AIR control)
B* Pnk (Red) INJ1 TBI (TBI)
B* Pnk/Blk (Pink) INJ1 (V6)
B* Pnk/Blk (Black) INJ1 (TPI)
C* Brn/Wht ECM / CE Light
D* Brown (Tan/Wht ) Fan
E Wht/Blk ALDL (pin B) / ECM (test)
F Pnk/Blk IGN fuse / ECM
G* Pnk/Blk (White) INJ2 TBI (TBI)
G* Pnk/Blk (Pnk/Black) INJ2 / (V6)
G* Pnk/Blk (Black) INJ2 (TPI)
H Tan/Blk ALDL / TCC-ECM (auto)
H Tan/Blk ALDL / Upshift (stick)
J* Org ALDL (pin E) / ECM
K Brn/Yellow (brown) ECM / Buffer
L Drk Blue (purple) Vats to ECM
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch
P
R Ppl/Wht Crank Fuse / Cold Start-ECM
P
71Camaro-Norway
Apr 10, 2020 06:02 PM
