Is a non-vats steering column compatible with a 91 RS
Old May 6, 2020 | 11:30 PM
86Lucille's Avatar
Wrote a long thread and just decided to keep it short. What will I have to do in order for it to run properly? Bypass the VATS? Just recently bought a v6 91 RS with no steering column and I’m just wondering if I can save some money by parting out my rusted flintstones pos 86 sport coupe. I know that the v8 steering shaft will have to be used because the v6 one is significantly shorter. Will the cluster and stock ECM work properly once I get this figured out with a carbed sbc? Just trying to get this v6 running in the mean time. Thanks.
Old May 7, 2020 | 11:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Is a non-vats steering column compatible with a 91 RS
There really isn't a VATS/Non-VATS column, only the early column, mid year and late. There is no V6/V8 shaft, they are the same parts.
The "VATS" is just a lock cylinder with a set of wires coming off of it. You don't need to do anything with the column if you're taking EFI off the car. You will need to bypass the starter relay, or ground the small black wire off the relay to get the car to start after though. Just take the clumn out of your other car and install it
Old May 7, 2020 | 12:08 PM
86Lucille's Avatar
Thanks for the info. It really cleared some things up. I just thought that since it had a v6, that was the reason why the shaft was shorter but I just realized maybe because it is a different era column, hence the smaller steering shaft.
Old May 7, 2020 | 12:24 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The shaft is colapsable, it's the same between the cars. Try pulling on it, put one end in the vice and pull on the other, it should give you some resistance, there is a wave spring in there so it isn't a sloppy rattle trap when installed
Old May 7, 2020 | 12:31 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by 86Lucille
......a v6 91 RS with no steering column and I’m just wondering if I can save some money by parting out my rusted flintstones pos 86 sport coupe......
My only question would be how well your 91 wiper motor circuit will tolerate the 86 wiper switch .
Old May 7, 2020 | 04:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That's a good point I hadn't thought about. Different switches for those years
Old May 7, 2020 | 05:51 PM
86Lucille's Avatar
Ehhh, won’t be driving it in the rain that much. Plus it snows, it doesn’t rain. It won’t be a daily.
kingantho82
Feb 4, 2018 12:59 PM
grlygirl
Interior Parts Wanted
Apr 2, 2010 07:45 AM
89Camaro89MI
Apr 28, 2009 08:56 PM
