New steering column. Car wont start.
Old Apr 26, 2009 | 02:52 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Hello thirdgen,
My tilt steering broke, so I switched in a new steering column, PITA, I got all the wiring reconnected, and the car wont start.
I imagine it's the anti-theft system. Here's the specs.
The car is a 5LV8, TBI 89 Camaro RS.
The new steering column is out of a V6 91 Camaro RS.
There's also an orange wire sticking out of the steering column which was spliced. If anyone knows off hand what it is, let me know.
I really dont have much experience with auto electronics, and could really use some advice. I have both the old and new keys, and the old steering column as well, if this helps.
Old Apr 26, 2009 | 03:21 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New steering column. Car wont start.
your new key has the wrong resistance. Your car is looking for the resistance in the old key. Of course, now it has the wrong teeth.
Old Apr 26, 2009 | 04:26 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
https://www.thirdgen.org/forums/elec...able-vats.html this will help read it all!!!!!
Old Apr 26, 2009 | 09:49 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I'm in the same boat, I haven't started my car in over one year, oh well I guess I'll wait for a definate response
Old Apr 27, 2009 | 01:07 AM
Transmission: stock
ok guys here is the best I can do, short of comeing to your car and tracing it out and then fixing it. VATS is a bit** at best. the easiest thing to do is call a chip burner and have them cut you an eprom that disables the VATS system. pm me and I will pm back with the outfit that I use. they have been doing this since the begining of TBI. the cost was under $150
Old Apr 27, 2009 | 04:15 PM
Car: 1989 Camaro RS
Engine: 305 TBI
I tried the resistor thing.
I havent got it to work yet, even adding the key's resistance in series and in circuit. I'll give it a few more tries before I switch over to looking for a prom burner.
thanks a lot for the info, though.
Old Apr 27, 2009 | 05:10 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
you can measure the resistance with an ohm meter and by the resistor we used to do that all the time with car alarms very simple you just read the ohm and put the resisitor on the COMP side of the wire NOT the column side in series and just leave the column side up under the dash
Old Apr 27, 2009 | 08:59 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
For me vats was one of the first things I bypassed. I installed the new (used) column but it wont engage. If I use a pair of pliers and pull on the metal rod that engages the starter it will turn over, but I can't adjust the actual switch for her to kick over normaly I adjusted her up and down and all around but still no help. I tested the switch using an ohm meter and it works Maybe I just need a different coulmn
Old Apr 28, 2009 | 08:56 PM
Car: 1989 Camaro RS
Engine: 305 TBI
I had the exact same problem. I just had to adjust where the slider sat under the bolts and tighten them down (they're hard to get to) I currently have the brights switch disconnected - it's supposed to sit on those bolts, but I'm thinking about wiring it up to it's own button, instead of the blinker toggle.
Maybe dropping the brights will help, or put some loctite on there, so the switch attached to that metal rod wont move.
Anyways, I bypassed the VATS and everything works fine now. Thanks all for the info.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
86Base
Aug 8, 2015 01:34 PM
