VSS
Old May 15, 2020 | 06:11 PM
donnybee's Avatar
VSS
Hello folks, this is my first post here, so here goes. I have a 85 Z-28 that i bought without motor or trans. I transplanted a 88 tbi motor from chevy truck with th700r4. Originally the car was a v-8 carbed 5 speed. It has a gear driven speedo cable and the new motor has electrical. I have read that this car has a vss box on or near the speedometer. I know i can change the vss from electric to cable with the replacement on the trans so i can have a speedometer. So my question is can i use the output from the speedometer vss for the input to the ecm so i can use the cable to operate the speedometer? I have the 1227747 ECM and i believe it requires 2000 pulse to work correctly. Or will I have to install a signal generator between the cable output on the trans and the speedometer cable?
Old May 15, 2020 | 07:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS
https://www.tpiparts.net/inc/sdetail/7586
Old May 15, 2020 | 08:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS
Originally Posted by donnybee
...I know i can change the vss from electric to cable with the replacement on the trans so i can have a speedometer. So my question is can i use the output from the speedometer vss for the input to the ecm so i can use the cable to operate the speedometer?...
Yes, that works. The optical VSS on the speedometer will provide the proper 2K PPM for the '7747 ECM.
It sounds like you understand the required mechanical changes to the transmission. IIRC, will need a tailhousing that has the torque arm mount. Along with the drive and driven gears and cable mounting insert to go with it.
RBob.
Claudioa
Jan 22, 2018 07:29 PM
randallp504
Jul 31, 2017 08:33 PM
AustinT
Mar 13, 2004 09:55 AM
89IrOc350
Nov 25, 2002 12:14 PM
IROCZ88
Jun 24, 2002 11:23 PM
