No lights on dash buttons.
Old Dec 31, 2020 | 05:28 AM
KR81's Avatar
Does anyone know how to fix the bulbs in these switches ? My hatch release and rear demister buttons no longer light up.
Old Jan 16, 2021 | 06:01 AM
KR81's Avatar
Re: No lights on dash buttons.
Anyone ?
Old Jan 26, 2021 | 10:14 AM
BenCramer98's Avatar
Car: 1986 z28 camaro
Engine: 305 tpi
I’d just replace them but I’m sure they’d cost you an arm and a leg for reproduction.
Old Jan 26, 2021 | 11:49 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
There's a thread somewhere on TGO where someone replaced all of the lights in the switches with LEDs. The hardest part seems like it would be popping-off the switch "caps" without breaking them. Here are some pictures of an old one I use for testing.
This one shows one of the caps off, and you can see the light down inside of it.
In these next two, you can see the tabs that the cap pops onto/over.
And in the last pic, which you can see on the back of your switch, is how the two wires from each bulb are soldered onto the terminals.
I've never done it, but it looks simple enough. But if all of the lights in all of the switches have gone out, which is how the title of your thread reads, then I'd suspect the dash lights fuse, because it's not likely that they'd have all given up at the same time. So I'm guessing it's not actually all of them?
Gtatransam1987
Aug 6, 2015 02:00 PM
wager420
Sep 28, 2011 02:07 PM
thecraze
Jan 19, 2010 08:51 PM
Project: 85 2.8 bird
Sep 1, 2003 05:08 PM
