knock sensor and coolant sensor
Old Jan 13, 2021 | 09:31 PM
wayniac's Avatar
Car: 88 GTA
Engine: 5.7
Transmission: auto
please helpme!!!!!grrrrlol.Can some body please tell me what color wire goes to the knock sensor,I know the manual states dark blue but mine has a yellow wire going to it.And then there is a solid black wire going to coolant sensor above the knock sensor which mine is black.I think these maybe mixed up.I bought this car like this with alot of driveability concerns.88 gta 5.7 btw.Thank you in advance
Old Jan 13, 2021 | 09:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: knock sensor and coolant sensor
You can ohm the esc to knock to determine the color. Or ground either and see if the fan comes on. If it does by grounding that’s for the head switch.
Old Jan 14, 2021 | 08:10 PM
Turn the key on. Ground the center pin of each connector, while disconnected from anything else.
Whichever one turns the fan on, is the fan wire. (duh) The other may or may not be the KS wire but at least you have a beginning.
harmoe
Aug 7, 2019 05:17 PM
MI ROC-Z
Apr 16, 2010 10:21 PM
RedWagon42
Dec 23, 2002 12:57 PM
colincamaro
Jun 24, 2001 12:04 AM
Iroc_Z28
Oct 14, 2000 08:13 AM
