Rear hatch doesn’t open with switch
Old Jan 14, 2021 | 09:13 PM
Iroc588's Avatar
Car: 86 Trans Am,x2 1986 Yellow/Red Iroc
Engine: All 5.0 LB9 TPI
When I bought the car the guy said it was a ground that was making it not work but I haven’t been able to figure anything out I had the switch working for maybe a week then it stopped really can’t figure anything out any help would be greatly appreciated
Old Jan 14, 2021 | 10:20 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Rear hatch doesn’t open with switch
Check the wires under the console switch. I have seen a broken wire in there just a few inches from the switch.
Also, check all your fuses
Old Jan 15, 2021 | 07:34 AM
Abubaca's Avatar
I had a ground on the switch go bad out back by the release mechanism. I repaired it, it worked for a bit, then stopped. Turns out the the area where the factory had it connected just wasn't grounding very well. I moved it onto a brand new area/hole, and sanded it down for a good contact and haven't had any issues since. ...but of course, check the switch, fuses, etc. etc.
IROCK ZZ
Mar 17, 2024 10:14 PM
9SecV6
Sep 8, 2006 08:53 PM
Mr.W
May 8, 2004 08:53 PM
