What to lookout for
Old Feb 20, 2021 | 07:27 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
What to lookout for
Finally did ac delete
i finally did the ac delete and in the end got bored and decided to clean up wiring. V6 to v8 swap. If i completely remove the ecm do i need to worry about VATS? My FP cooling fans, And radio run through fuse block. And the fan is controlled by temp switch. Of course i still have stock lights.. Amp is direct wired. i took bolt out of c100 block and completely took ecm and wiring harness from passenger side. I have to keep ign, starter, alt, dizzy, and all fusible links, i dont want to just have cutoff wires i want it looking CLEAN. Oh and what about airbag? I hve no oil pressure switch. And have Aftermarket gauges. And have secondary MANUAL fuel pump switch. If there is anything that needs to be remembered or taken care of please let me know
rottweiler68
May 5, 2023 11:49 AM
QUICKCHICKEN
Nov 6, 2017 02:39 PM
BeyondZ28_85
Mar 28, 2016 12:45 PM
kreator33
May 29, 2012 02:36 AM
BTS88IROC
Jul 1, 2003 09:11 PM
