Swapping 6.0 in a digtal dash help?
Old Mar 31, 2021 | 11:43 AM
88GTAP's Avatar
Hey guys so my dad just got an LQ4 engine for his 1988 trans am and it's got the digital dash and that's the only thing holding him back from swapping it in do you guys know anyway to get the stock dash to work with the LQ4 or if there is any other quality digital dashes out there?
Old Mar 31, 2021 | 03:50 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Swapping 6.0 in a digtal dash help?
It's the same as any other swap, nothing special about the digital dash
Old Apr 4, 2021 | 10:57 AM
88GTAP's Avatar
so it’s essentially the same as wiring up a normal dash?
Old Apr 9, 2021 | 09:37 AM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
Mostly, with the exception that your tach won't cover the range needed for the new engine. They have a redline above the 5200 displayed on the dash, so if you plan on setting the redline above that (or even 6000 like some do), then you'll either need to have a custom LCD made with the the wider range or install a tach converter box from dakota digital and put a decal on the display with the new number range.
jsmith929
Mar 25, 2021 12:27 PM
Steveh4263
Oct 12, 2008 05:25 PM
Matt
Apr 21, 2004 10:39 PM
