New American Auto Wire Highway 22 Wiring Harness Questions....
Old May 4, 2021 | 03:07 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Hey,
I have a 91 Firebird 5.0 TPI 5 Speed...
Sadly, my car / factory manual are in FL and I'm in WA Hoping to fly to FL in late June then UHaul it back to WA, 3,200+ miles...
Anywho, I plan to install (uh, pay a professional) a new American Auto Wire Highway 22 wiring harness, car alarm, custom wiring, etc...
I have an EBL P4 7730 ECM, VATS has been disabled / removed from the car. Engine / ECU and Engine Wiring work fine...
Just trying to plan circuits / amps, etc...
My first question....
What do I need to power from the fuse box to "run" the engine?
Fuel Pump - 20 Amp Circuit
ECM - Battery and Ignition hook up - 20 Amp Circuit total - 10 each circuit
Injector 1 - 10 Amp Circuit
Injector 2 - 10 Amp Circuit
ESC Module - ? Amps ?
Anything else?
How many amps does the ESC Module need?
Thanks, I'll keep posting questions in this thread as I progress.
Rafael
Old May 4, 2021 | 06:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: New American Auto Wire Highway 22 Wiring Harness Questions....
It's not what the device needs, it's what size is the wiring supporting it. Smaller is always better if you don't know on the fuse.
I run the entire LS engine off a 40 amp supplied circuit and I run smaller fuses for the components than GM did from the factory for some of them.
You're probably fine with a 5, 7.5 or 10 amp fuse for the ESC
Old May 5, 2021 | 12:12 PM
luvofjah's Avatar
Those amp ratings were pulled from the diagrams I could find online / dynamiEFI, etc...
It's just a starting point...
Or more to the matter at hand, will it start at this point???
Old May 5, 2021 | 01:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Ignition coil?
Matthew91-Z28
Car Audio
47
Jan 23, 2021 06:55 AM
soul.justice
Car Audio
Jan 20, 2013 07:47 PM
89ROC-Z
Jul 12, 2009 10:16 PM
1986CamaroSC
Car Audio
Jun 2, 2002 03:38 PM
speedfreaker
Car Audio
Apr 14, 2002 07:14 PM
