Cruise control.. whats this hook to under the dash?
Old May 22, 2021 | 07:54 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
removing what I don't want.. whats this hook to under the dash.. ? Vac line to what? its a single wrapped line/plug.
yes know it Cruise control.. but whats it go to under the dash..Larg Size vacuum line and plug set.. all by its self. going into fire wall.dont need Cruise control. any more.. was just going to cut and remove..
Old May 22, 2021 | 08:58 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: Cruise control.. whats this hook to under the dash?
There is a switch attached to your brake pedal assembly that the other end of that vacuum line attaches to. It threads into the bracket above the brake pedal. It's easy to see, so remove the vacuum line so that your cruise removal is complete.
Old May 22, 2021 | 09:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I believe the plug was a mix of wiring from the controls on the signal stalk, brake sw or VSS buffer (w/o looking @ a diagram..)
The vac hose went to brake switch and vented the cruise vac diaphragm as a redundant(?) for making the cruise unit release when hitting brakes.
Old May 22, 2021 | 09:18 PM
thank you for the replys... just wanted to know...what I would destroy before going at it..getting bay set up for the repaint. and removing what I can.. seen the Plug/Switch On/for the brake pedal. when Removing the Brake booster..but did not look at it close..
Old May 22, 2021 | 09:22 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The cruise harness is "stand alone", you should only need to disconnect the connector and vacuum port and then remove the grommet through the firewall and no cutting necessary
Old Oct 16, 2022 | 02:29 PM
bluehog's Avatar
Car: 84 MSE TransAm #22
Engine: SBC 350 +.060, Holley Sniper EFI
Transmission: 1991 T5 WC
Axle/Gears: Eaton TrueTrac in Dana44 case- 3.31
Bring this back from the dead... just got done messing with this connector. & hose It goes to the Servo unit that on my '84 is inside the engine compartment near the LF headlight, not under the dash! Only way to get to the connector is to unbolt the servo from below car (2) with 13mm socket, the hose goes on top. Sorry no pics of the back connector but you have a good one. I had to replace the boot, what a PIA! Still trying to get the CC to work after ECM & wiring removal
Attached Thumbnails Cruise control.. whats this hook to under the dash?-20210418-img_4291.jpg
ZZ42Fast
May 1, 2020 11:43 AM
91 camaro racer
Aug 7, 2007 01:18 AM
coincounters
Apr 25, 2005 10:55 PM
IceManRS305
Jan 12, 2005 05:56 PM
