The Cruise Control Delete Thread
Old Oct 11, 2013 | 02:33 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I've searched and searched but can't find a TPI guide for removing the cruise control unit.
My car is an 88 IROC and I want to remove as much as possible.
Anyone have any pictures of what can be removed? How to I plug tubes that aren't needed?
Any advice?
Old Oct 11, 2013 | 05:09 PM
Guest
Guest
Posts: n/a
Re: The Cruise Control Delete Thread
Any advice?
what, this is so simple.
Just unplug and unbolt everything thats attached to it.
-don't forget the vacum canister too.
Old Oct 11, 2013 | 09:58 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
The cruise control assembly is the stick on the side of the column, the box in the driver's side kick-panel and the unit that actuates the throttle. I kept the box and the wires that weren't connected to the actuator in the car. PO swapped sticks and didn't put a cruise control stick back in. You'll want to plug the vacuum line coming off of the plastic bit where my hand is.
2 bolts on the bracket on the bottom to remove it.
Old Oct 11, 2013 | 10:03 PM
Guest
Guest
Posts: n/a
My boost gauge line is hooked into the vacume hose that (used) hook into the cruise control.
Old Oct 11, 2013 | 10:12 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
WHY?
Old Oct 12, 2013 | 02:35 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks Dakota that is really helpful.
Why? It didn't work anyway, I will never use it, it could be leaking, it's ugly.
Old Oct 12, 2013 | 02:38 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks also. I figured it was a simple one but also want to make sure I don't forget or leave anything
Old Oct 12, 2013 | 10:03 AM
Guest
Guest
Posts: n/a
Naw, you'll be goo man. Im full gutted under the hood. Both frame rails and al of the firewall see full day light. Also, ALL 8 plugs are changed from the top, and yo can see the pavement around my LTs.
(actually, the only things under the hood are mod parts and whats required to run.
Old Oct 12, 2013 | 10:07 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
So just been out and taken it all out.
First pic is what I did with the 'T' that feeds the vacuum canister and the HVAC (heater vents). I removed the long line to the canister and decided to run a tube direct from the plenum into the firewall for the HVAC. As far as I'm aware this will just effect the position of some of the vents depending on vacuum available from the engine- no big deal for me.
Then I removed the actual Cruise unit (only 2 nuts) and pulled the throttle cable. There are 2 holes for vacuum line, one small and one large-
The smaller one seems to have fed the canister (also known as the orb of power) and through a T also fed the HVAC as discussed above.
The larger vacuum port- I removed the hose and plugged it as so-
Was this right? Not too sure about it.
Anyway went for a cruise and it all seems ok.
Any suggestions or feedback?
Old Oct 12, 2013 | 10:13 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Larger hose goes to the Switch by the brake pedal. No need to plug it- it is there to quickly vent the vacuum from the cruise when the brakes are touched.
Old May 1, 2020 | 11:15 AM
Tidan's Avatar
Is it okay to remove the vacuum line that has the wires taped to it and the connections near the brake pedal or does this have some functions other than cruise?
Old May 1, 2020 | 11:43 AM
Drew's Avatar
This thread is ******. The vacuum reservoir is for the dash vents, it's just a convenient out of the way place to tap into engine vacuum. Just replace the tee by the battery with a hose splice connector. The entire cruise harness from the servo thru the firewall to the dash harness can be removed as one piece. Unscrew the ground wire by the brake booster, pop the rubber grommet out of the firewall, and disconnect the wires under the dash. The controller box under the passenger side of the dash isn't worth messing with, it's just a light plastic box with a printed circuit inside.
eightsixseven
Dec 16, 2024 01:50 PM
toones
Jan 6, 2016 06:00 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
