Holley HP Speedometer
Old Jun 29, 2021 | 09:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I finally got my speedometer working
I have a Holley HP and bought a driveshaft speed sensor that goes on the diff pinion
https://www.motionraceworks.com/prod...action-control
I hooked into the holley as an input, then display it on the Holley 3.5" LCD screen
Expensive , yes, but one of the limited options I have with a powerglide trans
I'll also be logging this at the track to see wheel slip
Old Jun 29, 2021 | 11:13 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Holley HP Speedometer
Definitely nice to have the data logging of wheel speed. You could even use the Davis Traction control now if you want.
For dash gauges, did you consider using a Dakota Digital pulse generator with a signal conversion box to drive factory speedo? https://www.dakotadigital.com/index....rod/prd916.htm
Old Jun 29, 2021 | 11:32 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I looked into it.
But since I was going with a Holley set-up, it seemed like the right way to do it.
I also wanted to keep the interior some-what stock looking.
wruiz
Nov 15, 2019 09:39 PM
jo3h
Carburetors
Apr 30, 2007 11:43 PM
formulafastfoot
Carburetors
Aug 13, 2006 12:43 AM
65panhed
Carburetors
17
Jul 15, 2004 12:25 AM
