Wiper Motor Cam??
Old Dec 4, 2021 | 02:23 PM
boxingjunkie's Avatar
Wiper Motor Cam??
1987 Trans Am 5.0 TPI Auto
The bottom wiper motor is the one from the car. The one on top is a new one I picked up.
Been having issues with my wiper motor. It used to work fine but has since starting acting up. It has delay wipers but when I turn the stalk on the wiper will only work on high no other speed. It also does not go back to the home posiition. When turned on it rotates some of the time or the wipers just move a couple inches. I have since bought two more complete motors to try but have the same luck with all of them
Here is a quick video to show what it is doing. Im wonding if it is the cam inside???
https://photos.app.goo.gl/DfVkJ4Z4Em7njtyq8
Thanks for any help..
Old Dec 5, 2021 | 07:35 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Wiper Motor Cam??
Rebuilt motors or new motors? years ago, Years ago, on an older car, the wiper motor failed to park unless I turned off the switch. Tried two rebuilds with same problem (rebuilds do not replace the park mechanism. Purchased new motor and problem solved.
In your case the problem may exist upstream in the circuit.
Old Dec 5, 2021 | 05:19 PM
All three motors that I have are used motors have not bought anything new. I wondered if it not returning to the park position was in the switch but what would cause it to not even turn the wipers all the way. They move about 3 inches and thats it. That is why I thought it might be the cam inside.
Thanks for the help.
Old Dec 6, 2021 | 10:19 AM
72buickgs's Avatar
Car: 1984 Trans AM
The parking mechanism is invoked when the switch is turned off. It is within the motor itself. What u require is the wiring diagram from the switch all the way to the motor. U need someone to give u photos of the wiring diagrams. s/b 2 diagrams.
Old Dec 25, 2021 | 01:31 PM
Thanks for the help and info. I bit the bullet and bought a reman from Classic Industries and now everything works as it should. Should have just bought the reman from the beginning would have saved money and headaches. Thanks
Dark-Illusion's
Mar 25, 2011 08:33 PM
Dirtybird355
Jun 17, 2005 08:39 PM
ss85tadude
Nov 18, 2003 09:36 PM
