Help identifying this alternator?
Old Jan 15, 2022 | 06:44 PM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
H there,
This alternator seems to be going bad. I took it to 2 shops and they both said it charges for a while, then stops charging, then starts again. I would like to replace it, but I can't figure out which one it is. The previous owner installed it, and it is not an original style alternator for this car. The car is a 1991 Firebird Formula, it was originally a 305 TBI automatic, but is now a 355 TPI manual.
Anyone k now what part number it is?
Old Jan 15, 2022 | 10:44 PM
vorteciroc's Avatar
Top Answer: 1
Re: Help identifying this alternator?
It appears to be a GM/ Delco-Remy CS130 Model Alternator.
They were installed on Third-Gen F-Bodies... so they are not uncommon.
Old Jan 16, 2022 | 07:24 AM
KR81's Avatar
Looks exactly like mine which I'm coincidentally about to swap out as well as it has died.
If it is the same, its a
"Delco style" DXA505 12v 105a.
Old Jan 16, 2022 | 08:23 AM
OrangeBird's Avatar
Car: 1989 Firebird
If you look closely at the pics of the OP's alternator, and the alternator KR81 posted, you will see location differences in the electrical connector(specifically, where the red and brown wire's connector is in relation to the mounting ears). Those two alternators, while similar at first glance, are different looking enough to possibly explain what the OP is experiencing here. Of course considering KR81's car is a 1988 and the OP's is a 1991, perhaps there were different alternators, or perhaps they are supposed to be the same and the previous owner bastardized something to fit when he installed the 355 TPI. So now if they ARE supposed to be the same we're left wondering, what exactly DID the previous owner install when the engine work was done? It's not a V6 alternator, that's for sure because the connector locations are different on the V6 VS either of these two, so perhaps a V8 of a different model (like a Buick or something?) . At any rate, if it were my situation, I'd at least try and see if whatever alternator a 1991 V8 Firebird calls for could be fitted, perhaps the different connector location may not be a problem if the wire reaches it and nothing bracket wise interferes with it?
Edited to add, I just went to Rock Auto and looked up the alternator for a 1991 V8 Firebird and the one shown is exactly the one in the OP's car, leaving me to now question the parts people the OP is dealing with
Last edited by OrangeBird; Jan 16, 2022 at 08:43 AM. Reason: clarify my point.....
Old Jan 16, 2022 | 09:14 AM
For many alternators, the connector location is "adjustable"... tha alt itself is the same, it's just a matter of where the rear piece is oriented with respect to the front piece. Referred to as "clocking" the alt. For years, the 10SI was like that; you'd go to the parts store and buy one, and for some applications, you'd have to do that. Which was simply, remove the screws holding it together, rotate the pieces to some new orientation, and put the screws back in. Doesn't necessarily make it a "different" alt. Not sure if that's the same case here, I can't recall ever having to do that to one of those, but something to consider.
Old Jan 16, 2022 | 10:57 AM
On Probation
Thanks for all the replies. So I need a CS130. most of them are 105amps, is that sufficient for this car? It used to have A/C, but it doesn't anymore. If I put A/C back in someday, will 105amps be enough?
Are there any recommendations for a good C130? Any to steer clear of?
FormulaEngland
Jul 1, 2016 02:42 AM
mmc4vette
Jan 31, 2016 07:42 PM
Joeboy
Jun 12, 2008 12:37 PM
TBI89Formula
Car Audio
Jun 8, 2002 07:52 AM
