Wiring help
Old Jan 29, 2022 | 11:07 AM
Riegel's Avatar
Wiring help
I’m putting a 94 motor from a road master into 87 Camaro need wiring help I have the harness from the 94 how do I tie it in
Old Jan 29, 2022 | 11:15 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Wiring help
Why wouldn't you use the existing wiring from the '87?...
Old Jan 29, 2022 | 12:30 PM
Riegel's Avatar
Re: Wiring help
carb to injection
Old Jan 29, 2022 | 01:01 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Wiring help
I don't think your gonna find specific step by step "the red wire ties into the orange" type of instruction here, such swaps vary by the donor powertrain being installed.
With that said, in general, you will of course want to get the full wiring diagram for both the 87 Camaro and the 94 Buick , and then make sure you wire in the 94 harness to receive all of the power, ground, and signal inputs/outputs that the 94's system had when it was in the Buick.
Old Jan 29, 2022 | 01:09 PM
T.L.'s Avatar
Re: Wiring help
A 1987 Camaro would have fuel injection from the factory. Did a previous owner swap it to a carb?...
Old Jan 29, 2022 | 03:26 PM
Re: Wiring help
87 was the last year of the LG4 in these cars. So, yeah... Or of course, coulda been a swap. What's the 8th digit of the car's VIN?
Is this Roadmonster engine a L05 (TBI), or is it the LT1?
Old Jan 29, 2022 | 03:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Wiring help
Have you seen the stickies in the engine swap forum? That might get you the jump start you need on your project.
https://www.thirdgen.org/forums/engine-swap/
Old Jan 29, 2022 | 07:16 PM
T.L.'s Avatar
Re: Wiring help
Wow, I thought '86 was the last year for carbed thirdgens...
Old Jan 30, 2022 | 05:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wiring help
These f-body's can be confusing. '87 was the last of the carb'd cars. In '88 the choices were TPI, TBI or MPFI (V8, V8, V6). Which continued until '92. Note that TPI and MPFI was available starting in '85.
Then trying to keep track of center bolt or perimeter bolt valve covers, 1-piece or 2-piece RMS, then roller or non-roller cams and the head just spins...
Then of course are the rear disc brake setups, the rear axle types, axle spline count, and the SAE versus metric brake lines. OK, I'm done, I think my head just did a 360...
RBob.
Old Jan 30, 2022 | 06:30 PM
T.L.'s Avatar
Re: Wiring help
RBob.
Okay, so I guess '86 was the last year for the L-69, but '87 for the LG-4...
Old Jan 31, 2022 | 10:08 AM
Re: Wiring help
L69 continued until 88 in the MC SS. Not these cars though.
Not sure what year or what platform was the last victim when the LG4 finally was put out of its misery.
87iroz-c
Dec 9, 2021 04:52 PM
jlpunt
Jul 17, 2021 06:34 PM
Need4Speed1387
Mid-West Region
Apr 6, 2004 08:27 PM
