Choosing a Shunt Resistor
Old Feb 14, 2022 | 02:07 AM
Yehuda's Avatar
I'm trying to do a power analysis on my target, which runs on 3.3 volts. Without the resistor, the average current while running is roughly 140mA.
I used a 10Ohm resistor as a shunt resistor with a 5V power source. The voltage difference between VCC PIN and GND was measured using a shunt resistor linked between 5V and the target VCC pin. (The decoupling capacitors have been removed.) On the other hand, the oscilloscope lacked a proper power consumption line.
Is there a problem with my setup? Is there any guidance on how to choose a shunt resistor?
Bennie Townsend
Pacific Northwest Region
Oct 30, 2020 01:46 PM
Mike Gibson
Car Audio
May 23, 2018 11:04 PM
1932 305TPI
Feb 28, 2015 10:00 AM
Saar
Jun 28, 2014 06:55 PM
SMURFN' Z28
Nov 9, 2005 11:20 AM
