Weak spark
Old Mar 18, 2022 | 03:55 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Weak spark
Weak spark on cylinder 1 new Ac Delco wires and e3 plugs along with cap and rotor plus accel cool any help with this would be great 91 z28 5.7 tpi bone stock
Old Mar 18, 2022 | 09:04 PM
vorteciroc's Avatar
Top Answer: 1
Re: Weak spark
Swap Spark Plugs with a different Cylinder and see if there is any change.
If no change then look at:
...Ignition Wire #1 resistance?
...Distributor Cap Corrosion inside at Contact for #1 Cylinder?
Old Mar 18, 2022 | 09:09 PM
87350gtanj's Avatar
Re: Weak spark
There E3's I usually run Delco's
Old Mar 18, 2022 | 10:05 PM
NoEmissions84TA's Avatar
Re: Weak spark
SWAP means interchange. See if the problem moves.
Did you look at the plug for the proper gap? If you, or someone else dropped it, then it will not function as designed.
If you got a little too crooked with the spark plug socket, then you might have cracked the porcelain.
And NEW does not automatically mean GOOD.
Arts89Iroc
Jul 8, 2011 08:25 AM
Iroc_87
Mar 11, 2009 01:00 AM
snisbet375
Mar 7, 2003 09:40 AM
MoJoeVanilla
Dec 4, 2002 12:01 AM
Druo-Z28
Mar 7, 2002 02:31 PM
