Spark Plugs
Old Dec 1, 2002 | 06:00 PM
MoJoeVanilla's Avatar
Spark Plugs
I just broke one of my spark plugs while checking them so i'm replacing them, which spark plugs should I buy for some extra performance??
Old Dec 1, 2002 | 10:41 PM
MdFormula350's Avatar
a/c delco i seem to like.. however run a search on here and find out what others like also..
Old Dec 2, 2002 | 12:28 AM
darbleinad's Avatar
Car: 84 Trans Am
ac delcos will work just great. they are good quality and well priced.
Old Dec 2, 2002 | 12:56 AM
radiateu2's Avatar
plugs
another for ac/delco champions are good to and priced right
Old Dec 2, 2002 | 09:48 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i doubt yul get a performance increase.
either the hole fires or it don't ..
I like NGKs. They seem to span a wider heat range with fewer plug #s. That tells me that they can manage to keep the plug from fouling or contributing to detoniation better than ACs.
They are usually about $1.45 each
Old Dec 3, 2002 | 08:59 PM
Pontiacman's Avatar
If you are a cheapo use the recommended AC delco's THey are made for GM engines.
Champion is for Fords
NGK is for Imports
You can mix them up, but it may not run as efficient or you may be changing them more often
I'm using Bosch Platinum +4's they give a better burn in the cylinder giving you slightly more power, and about 1 mile per gallon more. They are expensive though
Old Dec 3, 2002 | 09:33 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
[i]I'm using Bosch Platinum +4's they give a better burn in the cylinder giving you slightly more power, and about 1 mile per gallon more. They are expensive though [/B]
i beg to differ the spark can only go to one electrode so having it split it into 4 won't help, the spark itself can't split. i used to have bosch's and the car ran horrible, switched to AC's and it ran like a dream and others have had the same results. AC's all the way, doesn't matter how cheap they are
Old Dec 3, 2002 | 10:28 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
We had a big thread about this not even a week ago. The general consesus is that most regular generic plugs will work just fine. AC Delco's were my spark plug of choice until i put headers and used accel shorty plugs. All of those other expensive plugs are a waste of money.
Old Dec 4, 2002 | 12:01 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
NGK is for Imports
Ya know, GM started using AC Delco Iridium plugs which are actually rebadged NGK plugs. They say AC Delco on the porcelain and NGK in fine print on the nut of the plug.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
