Voltage drop
Old Mar 19, 2022 | 09:01 AM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Voltage drop
91 z28 had my scanner plugged in and noticed a voltage drop when I put the car in gear charging system tests fine any ideas?
Old Mar 19, 2022 | 09:54 AM
ULTM8Z's Avatar
Re: Voltage drop
How much of a drop?
Old Mar 19, 2022 | 10:12 AM
87350gtanj's Avatar
Re: Voltage drop
Drops from 14.1 to 13.5
Old Mar 19, 2022 | 11:24 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Voltage drop
probably normal from the drop in alternator speed when placed in gear.Possible you have weak alternator/bad connection(s) what does voltage read when head lamps,heater blower,fans, etc are on and engine speed is at above idle RPM ?
Old Mar 19, 2022 | 01:50 PM
ULTM8Z's Avatar
Re: Voltage drop
Yeah that's what I was thinking as well.
Can test that theory by slightly raising the RPM in gear and see if that 1/2 volt is recovered.
pontiacsteve
Jun 17, 2006 12:31 AM
gonzo1028
Jan 16, 2005 12:44 PM
ScrapMaker
Jul 6, 2004 08:08 PM
alivegy
Aug 18, 2001 12:32 AM
TINFY Racing
Sep 20, 2000 09:40 PM
