Fixed Tach but now oil gauge is dead
Car: 1985 Camara IROC-Z
Transmission: 4 speed automatic
On my 85 IROC the tachometer was pegging at normal speed. I replaced the control board and the tachometer and now I have good RPM readings, BUT now my oil pressure gauge is dead, no movement at all. The oil gauge pin on the new tach control board shows GND and it snaps into the cluster control board. How does the oil gauge get it's reading?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fixed Tach but now oil gauge is dead
Oil pressure gauge gets signal from
a canister sender rear of engine by distributor.
Thanks, I'll take a look. It's strange that it went out after I plugged in that new control board... possible bad board. I'm gonna try and put the old one back in to see what I get.
Car: 1989 IROC-Z
Engine: L98 350 TPI
I'd try a quick uninstall, contact cleanup, and wiggle jiggle reinstall before swapping parts.
motleykent
Interior Parts Wanted
Sep 24, 2021 01:47 PM
