Code flashes
Old Mar 22, 2022 | 07:05 PM
Nico1988's Avatar
Code flashes
Flash rhythm:
1...5secPause...1,2...5secPause...repeat
Whats does it mean anybody with an knowledgeable answer thanks.
Old Mar 22, 2022 | 10:32 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Code flashes
Originally Posted by Nico1988
Flash rhythm:
Sounds like Code 12 which means no trouble codes detected. The system repeats itself three times so you have plenty of time to write down codes if present.
Is your check engine light on?
Old Mar 22, 2022 | 10:37 PM
Nico1988's Avatar
Re: Code flashes
Yes I sat and figured it out your correct it is 12 and also when I sat with it running in park yes the check engine light is in a consistent flash but never dies out.? It's a 1987 chevy R10/C10 as well thanks.
Old Mar 22, 2022 | 11:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code flashes
Field service mode if your doing running
Old Mar 23, 2022 | 10:32 PM
Nico1988's Avatar
Re: Code flashes
Hey friend,just an update I cold started my c10 this tonight 1st time since I've worked some OT but there was no engine check flashing consistently no check engine on what so ever and let it run for 20mins so not sure what she's tryna tell me with the tick though...
88 350 tpi formula
Jun 1, 2012 08:47 PM
SatisTraction
Oct 17, 2007 06:01 PM
Uncle Skeletor
Oct 5, 2002 10:14 PM
Vikingbrew
Mar 10, 2002 09:52 PM
