Both turn signal dash lights constantly on
Old Mar 27, 2022 | 03:56 PM
willhewitt00's Avatar
I’ve just swapped my front parking lights for leds and swapped both flashers for led flashers. Now when I pull the light **** out one notch both turn signal lights on the dash are constantly on. They don’t turn off unless I move the indicator lever to one side or the other while the key is off, then that specific signal light on the dash will turn off. I have only replaced the two front parking lights with leds and have not replaced any of the other indicator lights with leds yet. Could that be the cause of this issue? Any help is appreciated.
Old Mar 27, 2022 | 06:50 PM
vorteciroc's Avatar
Top Answer: 1
Re: Both turn signal dash lights constantly on
Incorrect Bulb/ Bulb orientation...
Example:
Old Apr 9, 2022 | 01:03 PM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
You need polarity sensitive front side marker bulbs like below:
1982-92 Camaro/Firebird LED Front Side Marker Bulbs (screamingchicken.com)
Old Apr 9, 2022 | 02:35 PM
thanks for the tip! I did install the led side markers and everything works correctly now.
High~Cruzin
May 28, 2013 10:17 PM
Firebird_Sadie
Apr 7, 2012 07:45 PM
chevyrules85
May 5, 2008 06:51 PM
88305tpiT/A
Jun 27, 2005 09:58 AM
