Overcharging alternator
Old Apr 12, 2022 | 08:28 PM
Daniel89TA's Avatar
Car: 1989 Pontiac Trans Am
Transmission: 5 speed manual
I think I originally started this thread in the wrong place so I apologize if that’s the case. I have a 89 TA that is carb swapped. If I go out and make multiple stops the car will die. The alternator was showing high fifteen volts or more up to 20+ volts at times when I checked the voltage at the battery terminals with the car running. I got a reman alternator and it stayed just as high so I took it back. I got a new battery same thing. How can I fix the over charging issue?
Old Apr 12, 2022 | 08:46 PM
ULTM8Z's Avatar
Re: Overcharging alternator
The sense wire going to the alternator plug may have a problem causing the alternator to output much higher voltage.
Maybe probe the sense wire too.
Old Apr 12, 2022 | 08:50 PM
Daniel89TA's Avatar
the sense wire is the red wire coming off the alternator? Where can I probe it to make sure it’s working okay?
Teague
Sep 3, 2014 06:03 PM
Guro 305
Jul 24, 2009 05:27 PM
kammi10
May 23, 2004 03:16 PM
91Bird305
Jan 27, 2003 03:45 PM
Zirtbow
Jun 16, 2002 02:53 PM
